Russianwolf
A buddy of mine had a chipper/shredder that he said wasn't working right and that I could have. I jumped at it as I have a bunch of small brush to chip and even if I needed to replace the engine it be a small amount compared to a new chipper.
He pulled and cleaned the carb out and reassemble and could get it working okay while spraying starter fluid into the carb but it would stall out when he stopped spraying. Turns out he didn;t know about the fuel shutoff that was in the off position. :tongue: (I've already teased him about that) But I think the carb needs some adjustments to run smoothly. It has three screws.
One on the bottom that is supposed to be the "adjustment screw assembly" according to the parts diagram. Then two screws on the side of the carb with the left being the "Idle regulating" and the right being the "Idle adjust".
So what should I do to get this beast running smoothly? Right now I can start it and it idles okay but kinda goes vroom vroom vroom (pause) vroom vroom vroom. not exactly what I ;m used to with my mower.
