navycop
I want to put up some type of flourescent light in my backyard. The miilion dollar question is: Knowing how high up to put it for the maximum ground coverage (with out getting rediculas). What wattage to use?
I hadn't thought of halogan.Why not use a Halogen to light up the yard?
I'd recommend a metal halide lamp. That's what's used in most store parking lots. I used to do lighting service work and have worked on literally thousands of them.
The most common is 400 watts but that might be too much for a back yard. Try a 250w or 150w, that might be just about right.
You'll need to buy the fixture also. They have reflectors in them to magnify the light and a transformer to run the lamp. Go to a big box store and look in the outdoor lighting section, you should be able to find "wall mount" and "pole mount" fixtures, pick which ever one works best for your application.
As far as height goes the wall mounts are usually about 8' and the pole mounts are 12' to 20', approx..
