jthompson1995
Can anyone lend some experience in what kind of tools bits/drill rod I should get to make my own turning/hollowing tools?
I have an old stainless steel tool handle (don't know from what, I found it in the garage whane I bought the house) that will accept 5/16" round rod. I plan on drilling and tapping two holes for set screws to hold interchangeable tool bits in it. The handle is only about 5" long and will hold up to 2" of the bit in the handle. I would only be using it to hollow small pieces (ornaments, small hollow forms, etc.)
My problem is I know nothing about hardening or heat treating steel. I have found lots of places carrying drill rod and HSS tool bits that will fit but they talk about air, oil and water hardening and it's got me baffled.
Can any of these be used for making turning tools without having to heat treat/harden them? Is it possible, and if so what's the best way, to bend the rod to create useable hollowing tools?
Thanks in advance for any information you can lend.
