William Young
My quart of high gloss WB laquer arrived late this afternoon via greyhound bus so I went into my shop this evening and tried it out on a couple pens I had turned yesterday because I was waiting for the product to arrive before finishing.
There is definitely a learning curve to applying it (at least the way I am doing it) so I wont elaborate on that until I have got it to where I am totally satisfied with my procedure. But at this early stage I am delighted with the results. The film thickness of three coats of that has to be at least equivalent to a dozen applications of frction polish finishes and it is a lot more durable finish that should stand up to a lot of abuse and hard wear.
After experimenting with first semi gloss WB laquer and now with the high gloss version, I doubt if I will ever go back to friction polish finishes.
This finish is making some of my previous attemps look shabby now so I am going to dissasemble at least 6 to 10 of them (if not more) and either strip down and re-finish them or just use the hardware for some different pens.
Top one is Honduras rosewood with maple band and bottom one is my first olive wood pen and it has a walnut band.
The picture was taken with my camera with no flash and just my normal shop lighting.
W.Y.
W.Y.
