Mini Mill and a bunch of misc. machine tooling trade for ?
MattTheHat
Allen, Texas
I've got a Micro-Mark mini mill that I don't need. I got it in a package deal with some other stuff and simply don't need it as I've already got a much larger mill in the shop. Same with the tooling, either it came with the mill package, or it's stuff I'm no longer using.
I'd listen to a trade offer for just about anything pen-turning related, particularly triple start taps and dies, Cebloplast and Mosaic acrylic, other cool blanks, higher-end pen kits, big pen display boxes, special tools, heck, just about anything a pen turner or vintage pen collector might be interested in. I've included a cash price for reference or for those who might not be interested in trading.
I'm fairly new to the site, so to provide something in the way of a reference, my eBay ID is "inkwell" (100% positive feedback for 14 years).
I'll consider any trade or cash offer, this stuff is just clogging up the garage. More info or detail pics can be sent via email, if desired.
Thanks, Folks!
-Matt
MicroMark Mini Mill, #82573 - $500 - SOLD
This is the model that preceded their current offering, which runs $742, plus freight. As far as I can tell, the only difference is the color, the spindle arbor (MT#3 on this one, R8 on the new one), and this one has a 350 Watt motor, where the current model has a 500 Watt motor. The machine has obviously seen very little use. I tested it and it runs fine. Comes with the supplied tool kit, and the hold-down kit (which is an additional $50 on the new model). No manual, though I suspect it would be readily available from Micro-Mark. I can pack and ship via UPS (I have a daily pickup) , but the thing weighs over a hundred pounds, so I'm guessing that would run $70-85 depending on destination.
Micro-Mark Digital Level and Grade Gauge, #84519 - $25
MicroMark Mill Collet Set, #82575 - $50 - SOLD
J7316A to MT#3. Comes with 8 collets, the adapter, wrench and draw bar for the above mill. It appears that only one collet has been used. All are in excellent condition. With ratty cardboard box and foam insert. Collet sizes are 5/8", 9/16", 1/2", 3/8", 5/16", 1/4", 3/16" and 1/8".
MicroMark Fly Cutter Set, #82768 - $20 - SOLD
Appears unused, in original box. Cutters are all in plastic wrap.
MicroMark Mini Drill Set, # 82416 - $15
Haven't checked to see if all the drills are present. Appears unused.
SPI Adjustable Angle Gauge, MSC# 418-4940 - $100
Unused, in wooden box.
MSC Adjustable Hand Reamer Set - #2239929 - $65
All appear unused (in plastic/grease bags) except the smallest one, which has been used. The previous owner somehow managed to bend the very end of the shank. This could be cut off, or used as-is as a hand reamer.
OMW, Large Ball Turning Tool - $100
I have two. One appears unused.
OMW, Large Ball Turning Tool - $85
Used to turn one brass knob and about a half dozen aluminum ones.
Little Machine Shop Kurt-Style 3" Milling Vise, #2500 - $70
In excellent condition with original box, mounting hardware, handle and 360 degree swivel mounting plate.
Little Machine Shop LatheFaceplate, #1199 - $15
Appears unused. Fits MicroMark 7x14 mini-lathe, and possibly others.
Little Machine Shop MT#2-3/8"x24 Arbor, #1613 - $5
Unused, in package.
Yep, another one. Unused, in package.
Little Machine Shop 1-2-3 Block Set, #1233 - $8
Unused, in grease paper in the original box.
Little Machine Shop Arbor MT#3-JT33, #1806 - $7 - SOLD
In excellent condition.
Little Machine Shop Drill Chuck, #1148 - $15 - SOLD
Little Machine Shop, Universal Indicator Holder, #1251 - $5
Little Machine Shop Wood Turning tool rest for C6 Lathe, #2498 - $20
Never actually used, but it has been modified to better fit my 10" lathe. The right side of the rest has been shortened by approximately an inch. The part that is clamped in the QCTP holder has been milled flat to fit better, and the bottom of the support arm has had about 1/4" milled off at a 45 degree angle to provide more clearance. Comes with unused MT#2 spur-drive center.
Phase II+ QC Toolholder Set, #250-111 $185
Wedge type. Comes with the holder, mounting bolt, millable mounting nut blank, top nut, and one each of the following tool holders: #1, #2, #4, #7 and #10. Used, but in excellent condition. Sized for 9-12" lathes.
Value Chucking Reamer 9/32", #2310183 - $7
Appears unused, in tube.
Value Chucking Reamer 1/4", #2310167 - $6
Value Chucking Reamer 5/32", #2310100 - $6
Value Chucking Reamer, 5/16" - $6
MHC Angle Plate, 4-1/2x3-1/2x3" 418-4520 - $15
Unused, in box. I have two of these.
Used set of pen mills - $20
These were purchased at Woodcraft at different times over the years. I recently picked up a bunch of Whiteside mills and no longer need these. All are in very good condition except one arbor which I attempted to turn down just a smidge for a special project. Includes a single 3/4" cutter (two if I can find the other one), six arbors and a Whiteside storage box with clear cover. Arbors measure: .383", .355" (probably a 9mm), .339", .349" (this is the one I turned down a bit), .284" and .242".
PM replied.
The collet set is NOT an ER25 type as I originally thought. The MM part number is correct, but the collets are actually J7316A type collet set. The other end is MT#3. The collets measure 45mm in length, 24mm in width.
There are actually 8 collets (I forgot the one that was in the adapter. The sizes are 5/8", 9/16", 1/2", 3/8", 5/16", 1/4", 3/16" and 1/8".
-Matt
