I need help on a mandril
duxbutt
Nebraska
Hi All. I'm new to turning but ive ordered my first Lathe. my son ande I are going into this adventure on a first time deal. we Ordered a SEG #BenchA 156 through sears. the main question I have here is what taper do I need? 1 0r 2, what are the differences? Ive seen some lathes run a different number so I'm curious if anyone knows the correct direction to point me. we will up[grade in time I just want to see how much effort we are going to put into this. id love to own a jet but right know this is more feasible. Thanks Dan
Morris Taper
Here's a link to a pic of the two different morris tapers that came with my spindle (sorry, the image tag doesn't like my google url):
https://goo.gl/photos/FSwnYf32LYCGqF2X8
The one on the bottom (taper #1) has a maximum diameter (the thickest part of the taper) of 12.3 mm. The one on the top (Taper #2) has a maximum diameter of 18mm.
If you measure the taper hole, you should have an idea of which to use.
Hope that helps!
Here is a link to the company.
Wood Lathe Machine Make your own craftsmanship - SurvivaleEquipmentGear.com
It does appear to be an MT1 in both the head and tail stock. It is not optimal, but you can get mandrels and tools for it from most of the suppliers.
Happy turning.
That looks identical to the one I bought through Harbor Freight and it is in fact a #1MT...I just hope he didn't pay that much for it. :eek:
I have exactly the same lathe from Harbor Freight, paid around $100 with coupon, but there is a small problem.
The pic maybe wrong. The price is closer to HF's larger lathe and the description doesn't match the smaller lathe.
Compare descriptions, its a tad confusing.
The "manufacturer's" site has the right pic and description.
http://www.survivalequipmentgear.com/store/p1633/Wood_Lathe_Machine_Make_your_own_craftsmanship.html
The description for the Sears is for the larger HF I reference below.
http://www.sears.com/seg-wood-lathe-machine/p-SPM7683152626?prdNo=1&blockNo=1&blockType=G1
Wood Lathe Machine The lathe handles workpieces up to 10" in diameter and 18" long and features a pull-out switch to prevent unwanted or unsupervised operation. With a cast iron steel construction and nonslip rubber feet for reduced vibration, this wood lathe provides sturdy, reliable results on wood. Turn material up to 10" diameter and 18" long Five speeds: 750, 1100, 1600, 2200 and 3200 RPM Extremely sturdy cast iron construction to reduce vibration 1/2 HP, 110 volt motor 5 Speed Pull-out switch allows lock out to help prevent unwanted use Includes 3" faceplate and 7" tool rest Nonslip rubber feet 8" x 30" footprint Includes three hex wrenches, live center and spur center,..turning tool not included
http://www.harborfreight.com/5-speed-bench-top-wood-lathe-65345.html
With five adjustable speeds, this bench top wood lathe lets you tackle a variety wood turning projects! The lathe handles work pieces up to 10 in. in diameter and 18 in. long and features a pull-out switch to prevent unwanted or unsupervised operation. With a cast iron steel construction and nonslip rubber feet for reduced vibration, this wood lathe provides sturdy, reliable results on wood.
* Turn material up to 10 in. diameter and 18 in. long
* Five speeds: 750, 1100, 1600, 2200 and 3200 RPM
* Extremely sturdy cast iron construction to reduce vibration
* Pull-out switch allows lock out to help prevent unwanted use
* Nonslip rubber feet
* 8 in. x 30 in. footprint
OP if its this lathe Benchtop Wood Lathe - 5 Speed its Morse Taper 2
