How many sets of Micro Mesh?
JimB
West Henrietta, NY, USA.
Since micro mesh is used over and over again I'm wondering if people have more than one set to use for different things. I ask because even though I hit it against my palm and wash it once in a while it never really seems to come comepletely clean. It always seems to have CA dust in it and I was wondering if this will scratch the wood the next next time I use it. So, do you have one set to use on wood and another to use on your CA finish? Or maybe more than 2 sets? If you do, is it the same style MM (sheets vs pads)?
I clean mine with a fingernail brush, Not perfect, but it gets out most of
the junk. Just pop them in the sink with some dish detergent once a week or
so.. depending on how much I use them. I also don't let them dry out, so it
is easier to get the stuff out if it hasn't dried hard already. I keep them in a
bucket of water close to the lathe. (sheets .. 3x4? )
And yes, I have a set for wood and another for plastics, one more for metals.
I only use the little 2x2 pads from PSI, I think they're also MM, but only use them for plastics and to wet sand the CA finish on wood pens... I wet them in a cool whip tub and wash - rinse them after every use. Occasionally I'll use them to wet sand antler, but not every time I do an antler pen... depends on the antler..
I use 3 sets of MM sheets (mostly because I have 3 sets), so I keep one set for light woods, another for dark woods and the third for acrylics. To clean them, I just throw them in a fabric bag, and run them through the washer. Makes 'em good as new, and I have never worn out a set.
I melted a few pads when I started to turn pens :)
I bought a large set and cut it in 3 small ones so I guess I have 3 sets now. I only use two tho, one for wood and the other one for finishes. It might just be psychological. I usually only rinse them under running water and haven't really noticed any change in the past 6 months or so.
I have one set that I use primarly for plastic and CA finished pens. I wash them weekly and let them dry on a paper towel. They don't appear to have any residue and work very well. I usually wet sand with them and don't often use them dry because I melted one the only time I used it dry. When I want to sand wood really fine I use sanding sheets up to 6 micron and get a really smooth finish that requires very little work in the finishing department.
I was using one set for everything , but I just discovered that my local hobby shop has the 2x2 sets for $9 , so I now have 3 new sets . One for wood , one for plastics and one for metals .
Butch - what hobbie shop sells them for $9? The only place I've ever even seen them locally is Woodcraft and Rockler.
I think I'll be getting a second set rather than using 1 set for everything. Thanks for the answers everyone.
when i got mine a year and a half ago, i got the large sheets (4x8 i think) and cut them into 2 inch strips....
i don't use them on straight wood.....i use regular sandpaper through 400 and then seal with CA and the start with 320 and then 400 AND then go to MM....also, i only use my MM wet.....
just my 2 cents
It's just a little local hobby store (Mom and Pop kind of place) . He carries allot of goodies for penmaking , I get some of my metals (it's great when I only need one or two pieces of brass or aluminum and don't have enough of an order to get from my online supplier) , CA , dremel bits and he may have carried the MM pads for a while but I just noticed them on the rack .
I have several sets because I have more than one lathe and have friends over to turn so each area has its own MM. I use the air hose to clean between grit changes and this seems to work for me. I have been using MM for several years. Have not burned any when sanding for quite some time maybe it's because I am not as aggressive sanding or have listened to other turners that have helped me over the last few years.
I have a plastic organizer box with 1" strips in each compartment. I typically have 4-5 sets. 1 is reserved for maple and other light woods. 1 for dark woods, 1 for oily woods, and 1 or 2 for acrylic/polyester wet and dry sanding.
I use a "big eraser" to clean out the pores on my MM - a couple of passes and I'm back in business. Google on "sanding belt cleaner"
