jedgerton
OK, I'm stumped. I went to remove the live center from my Jet mini for the first time and things didn't work out as planned. I believe its an MT2 live center but when I used a jamb stick to remove it, just the outer hub and bearing slid off. If its an MT2, its hollow and it stayed in the end of the lathe. I tried to see if I could use a larger diameter jamb stick but it looks like the ID through the tailstock is the same size throughout.
Is the live center really an MT2 device and if so, does anyone know how to remove it???
John
John
