Help with Drilling BIC stick pens
refueler1
Indiana
I have made about 12 of these things and ALL are off center and it is driving me nuts. Anyone got a fix or have success drilling a straight centered hole on thier blanks. I am drilling on the lathe. Blanks are too long to drill on my drill press......??
I round the blanks to 1/2 inch, cut them to 3/4 inch longer than final size, pop the blank into the Beal Collet chuck, shoot the bit marked at the correct stop depth with a shot of PAM and drill at 50 RPMs, turning off the lathe each time I run out of tail stock.
I DO check the Beal each time before applying the bit to make sure the blank is turning as true as possible.
I have found the key to drilling this long, skinny hole is to apply the absolute minimum amount of pressure to the tailstock screw.
I hope this helps.
I have been pushing the tail stock into the spinning blank rather than turn the hand wheel and I have been drilling at very fast speeds..... Might have your suggestions. Thanks.
