Help !! with casing pens
pop1948
Midfield, Alabama, USA.
I would like to make some casing pens,cartridge pen liek the ones James Mann does with the whole casing. can anyone help with some instructions.javascript:insertsmilie(':D')
Big Smile :D
Here's the short version.
Drill out the rear of the casing.
Turn a wooden core on a 7mm tube to fit inside.
That's the short version. The long version is spread across about 300 posts here on the forum. Just do a search for the words "casing" or "bullet", you'll come up with lots of reading material.
David, make sure it doesn't have a Live Primer...
Used Primers are "punched" by the primer pin. The used primer must be removed. Thin punch or nail from inside cartridge, tap it out.
There is a tutorial by Don Ward in the library that has some very good information in it.
http://www.penturners.org/forum/topic.asp?TOPIC_ID=13621
Originally posted by jwoodwright
<br />David, make sure it doesn't have a Live Primer...
Darn [:(] You just took all the fun out of pop1948 learning.[:D]
chances are if the shell has a live primer then the bullet is still attached to the other end. check with your local gun club about getting some used/fired(empty) shell cases. they should be able to point you in the right direction.
if not send me a pm and i may be able to scare up some shell cases for you.
