Help please replace brass for Vertex Pen Kits
PenPal
Canberra, A.C.T., Australia.
I have a brass muncher secreted in my workshop or a secret pack rat or a failing memory.
Regardless of the cause I seek sources positive personal experiences with obtaining replacement tubes for the Chrome Vertex Pen KIt PKFP4000.
I purchased 3/8 10 inch tubes WRONG guess 3/8 drill should have rung a bell.
If you know where, how, cost, availability please reply.
Many thanks Peter from a long way away in AUSTRALIA.
Peter, Psi lists the 3/8 tubes under the acccesories page of the Vertex. Is the ID the wrong Size?
I believe the Atlas and Polaris and Patriot also use 3/8 tubes
Also, Exotics carries the long clicker pen kit tubes which use a 3/8 drill bit.
Brass Tubes If nothing Else give Ed a holler and have him measure them for you
pwhay, are you sure they are not the right tubes. The tubes that are listed as 3/8 should be the ones you need for a 3/8" drilled blank. I think you should check what you have, you probably have the correct ones.
Tim.
Dont know if this helps but i know the drill bit for the blanks on them is 10.5mm, cleaned today so garbage man got all my instructions for them
sorry thats for the vertex with the caps on them, it shows your model that you posted takes 3/8
