Pipes
Ok I chqanged mandrel shafts twice ! Iam not sure whats going on I have to keep adjusting the live center presure to keep it from making noise a diffrent noise than normal !! and my nib end is coming up out around !! But NOT on every pen I really don't think I have a BAD mandrel shaft ! The live center seems ok I am really confused and at a loss at what to do !!! Iam also I think burned out on turning ! maybe not but frustrated after today and this adjusting thing all the time and my nib end coming up just off center to small on 1 side on some pens NOT all pens !! I changed bushigs and It seem to help but not a complete fix HELP !!!! I doubt Iam burned out BUT I am confused and needed to step away from the lathe because everthing I tried didn't fix the problem !!! gona pick up a couple a shafts tommrow and just check and see maybe I got a couple a BAD ones IT can happen I guess !! HELP any Ideas !!!!
And yes I know NOT totighten the cewter down to tight and to hand tighten the madrel screw after I have set the live ceter and not to tight and and and Iam really confused this time ! Its NOT like I never turned befor I can normaly work thru most problems this one has me going guys !!
http://affordablepipes.com/
