Glue for loose pen parts?
Leicestershire, U.K
Hello folks
Sometimes i have a pen kit where the parts are an easy push fit into the tubes rather than a press fit- now i know that CA fumes trappped in the cap for example reacts with any black plastic parts and turn them a cloudy white- so what glue is o.k to use? would a 5 minute two part epoxy be o.k?
thanks
You don't want to use actual glue because if you need to dis-assemble for any reason you will not be able to. That is why the red loctite is recommended in the other thread.
