Why is this happening? I drill a hole, it veers off center and the chuck falls off, I'm spending more time reattaching the chuck than drilling.
What I think I've ruled out:
1. It isn't that the back end of the bit is pushed up too far, causing the taper on the chuck to attach all the way.
2. The table is not tilted.
3. The bit is coming down perpendicular to the table.
4. The main post on the drill press is perpendicular to the base.
5. I'm using a PH vice, it holds the blanks perpendicular to the base and there are no shavings under one side of the vice.
What I think might be the cause: The ends of the blanks are seldom truely square. 7mm bits are especially bad about veering to the side when they are pressed into the end of a blank that is not square. When it comes off I put a scrap block under the chuck and use the press to force it on tight. Is there a better way to reattach so it does not fall off with the slightest side pressure?
