Disassemble a Jr Gent II Ball Point – Help
WalkOn
Clio, Michigan
I like this ballpoint, but the clip is moving under the cap, lots. So, I thought I'd try and take it apart and apply some loctite. But the way this is pen is designed, it seems that I stand a real good chance of making a mess of this since the transmission is located in the upper barrel and I don't see how I can remove it to get to the cap. Any help would be appreciated.
Here is a link to the instructions showing the parts.
https://www.woodturnerscatalog.com/docs/jr_gentlemens_twist.pdf
Thanks,
Kev
The transmission threads onto the coupler and is not in the upper barrel when you pull the pen cap (top) off.
You have transfer punches I presume??
Right Ken, that makes sense now. The deal is that when I unscrewed the pen the transmission stayed in the upper barrel. I'll try working it again tonight and see if I can get out.
Yes I've got the the punches.
Thanks for the help.
Kev
Man, do I feel dumb. The two barrels are pulled apart, not screwed together. The pen has been fixed.
Good thing I don't do this for a living, I'd go broke.
Thanks again,
Kev
