Delta Lathe Problem - Please Help!
BLLEHMAN
Orlando, FL
I was sanding a pen blank yesterday and all ofthe sudden my lath slowed down to a snail's pace and its not a variable speed lathe. Its a Delta Midi (Model LA 200). Could someone please help?
Thank you,
First thing to try is see if you lost a keyway lock-----is the motor still running at the right rpm's. I will PM you my # and see if I can give you a hand.
