Delta 46-140 help
mkrevda
Byron Center, MI
I found a Delta/Rockwell 46-140 for sale for $100. It has an MT1 tailstock which is fine. The headstock does not have a MT taper and the threads seem to be an oddball size. Is there a way to just swap out the spindle out of a new model that has an 8-1 TPi and MT2 taper?
I would definitely pass on this old lathe. Watch and wait for a newer model lathe to come up for sale if you are going used. The #1 MT is okay for pens and light work but you would probably be happier with #2MT which is more standard and there are many accessories available.
You would spend more to get a new spindle and bearings...if one is even available.
Wait for something better/newer.
