Go to Home Depot or Raido Shack and get a spray can of contact cleaner. This is the product we used on multi-million dollar machines in the paper industry. It is safe to use, drys instantly, and is non conductive. Coke is an excellent rust remover, but I wouldn't recomend it for electronic devices. If you don't get it completely dry, it could short out your device. If you do use Coke, blow it out with compressed air to remove any moisture. You can also clean your contacts with emery cloth or sandpaper. Again blow out particals with comperssed air. Jim S
