AlanZ
Greetings all.
I'm just plunging headlong into the world of turning, and have a question about some chisel sharpening options.
I recently received a Nova Sharpening Center jig
http://www.teknatool.com/products/Other/Sharpening_Centre/Sharpening_centre.htm
And although I can set it up with a bench grinder, I'd really rather prefer to use my 2"x72" variable speed Bader belt grinder.
Now for the interesting question. I have both and 8" wheel, and a combination platen for the grinder, and I'm not sure which to use with the jig. I can rig up pretty much any kind of support.
So, which would you choose, and why?
Inquiring minds want to know!
- Using the wheel places an 8" rubber wheel behind the belt, and would produce a grind similar to an 8" bench grinder (resulting in a slightly concave grind).
- Using the combination platen places a vertical flat metal platen behind the belt (resulting in a flat grind). I can easily remove the toolrest from in front of the platen.
