Band Saw Parts
Greenville, NC
I have a Delta 28-276 band saw and while it was being moved broke both Trunnion's. Everywhere I have looked they are on back order. I read somewhere the the Grizzly would fit and they do look the same on the spec. drawings. Can anyone confirm this before I order them?? "plus they are cheaper"
I'm going to have to plead ignorance here, not sure what part of the saw the trunnion is, but I have a 14" delta band saw that needed a riser... I bought one of Grizzly's riser kits... the riser block fit perfectly, but I did have to grind off the little nubs that were to align the riser... and when I put the shaft for the blade guides on, it was smaller than the delta shaft... I could shim it in place, but chose to use the original Delta and just can't lower the guides below 6" inches to the table... otherwise all works well.
