PTsideshow
I posted a question in penturning about some new products and a mini chop/miter saw. I have the first edition HF 2" minisaw, I find that I have too heavy of a hand when cutting materials with it. It is great for small brass tubing, wood, and plastic material.
After looking around on the internet at what is available for a reasonable price. They have this saw on amazon as a factory reconditioned one for only $10.00 cheaper than what home despot sells a new one for. I also bought a Diablo non ferrous metals,plastic,laminated flooring etc. carbide 56 tooth. 7¼"dia. T
The only thing I don't like about the saw is the dust bag and chute doesn't work worth a crap. The chute tube plugs up@ the discharge. Other than that it cut a 2x4 in one pass and that blade did a very smooth job both with the grain and across. I have made around 30 cuts with it.
I think this will be a good size for pen work it is a 9 amp motor and has a nice clamp to hold the wood when cutting. It probably won't bog down when cutting. It also looks to have a removable/replaceable throat plate, so a custom one can be made to keep the small bits from dropping or jamming up. This blade was about half the cost of the saw. I haven't fine tuned it yet, the laser line is about as good outside as any of the others. It is light in weight and has a small foot print it will work, has a permanent mount carry handle on the back of the saw. It also has a chart of the compound miters for up to 10 sides, in 5° increases for us non fine woodworkers
I think this will be a great small item blank work saw. I have a 10" Porter Cable/laser cut on a a porta stand. It is a big pain in the seat cushion to set up and use in small spaces.
It is a Ryobi 7¼"Compound miter saw Model# TS1141
:clown:
:clown:
