12" Salt and Pepper Mill kits
southernclay
Dawsonville, GA
I need to buy a 12" salt mill kit, can only find 10" other than chefware specialties that says 4-5 weeks for deliveries. I've seen plenty of 12" peppermill kits but no 12" salt. Want to buy the style Exotics sells or CSUSA artisan type not the crush grind.
Anyone know of a supplier or have a salt and pepper mill kit they want to sell?
Be careful Warren.
The salt uses an anodized shaft, so the salt won't corrode it. I may have some longer ones, will check.
Point is, don't use a pepper shaft or it could look pretty yucky as it ages.
FWIW
Just checked, yes I do have 12" anodized. If you want to place an order, just order the 10" and note you want the 12" shaft (in the comments). I will substitute the 12" instead of the ten, same cost.
Hope this will work for you,
Ed
