barrel trimmer shaft
  1. B
    Barrel trimmer woe
    I own a barrel trimmer kit from PSI. The 7mm cutter shaft is worn and slightly bent. PSI says it cannot supply a new shaft as a replacement part. Several suppliers who sell 7mm shafts cannot guarantee that their 7mm shaft is compatible in size with the PSI cutter heads. Apparently this is...
