Woodchuck Pen Pro
PMisiaszek
Venice, FL and St Mikes, MD
I've been using my WPP on hard materials, like Tru-Stone and antler, and I am losing my sharp edges faster than I'd like. Have you had any success in honing or sharpening the edge? I know there was a thread on this sometime in the past, but I can't find it.
pensmyth
Reynoldsburg, Ohio
I have the Easy Wood versions of the Wood Chuck. When mine start to dull I hone them on a fine diamond file and it seems to bring the edge back nicely.
rjwolfe3
Mansfield, Ohio, USA.
Didn't know you could dull or sharpen the carbide cutters. Learn something new everyday. I will have to see if I can pick up a diamond file, I was just going to throw them away and use new ones.
bitshird
Adamsville, TN, USA.
A diamond Hone will work, just do the top, flat part of the insert, Just out of curiosity, how many pens are you getting per edge?? and which material.
PenMan1
Eatonton, Georgia
When I cut those materials, I just keep dipping the insert in ice water. Seems to make it last much longer. I've cut about 300 pens on 3 inserts, many tru stone and several alumimum ( I have a seperate insert just for aluminum).
When I cut aluminum or stainless steel ( and I know the tool is not recommended for steel) I use an oil called, believe it or not "cool tool" . The material cuts easily and the insert does make the little "ridges" like it does without oil.
Another "TRICK" that I learned with the Chuckie on acrylic (pr) is to put a big fan on full blast right behind my shoulder. The Woodchuck throws such a ribbon that the fan helps to blow the "PR Stringer" right into the dust collector without wrapping around the blank. I LOVE THIS TOOL!
bitshird
It's also not recommended for Chuck jaws or the edges of spur drives, you should see my 2 inch bowl jaws,:eek: and a couple of my spurs:beat-up:.. ""Damn those woodchucks"" :biggrin::biggrin::biggrin:
PenMan1
Eatonton, Georgia
All joking aside here, the inserts on the Woodchuck are sharper than me!
I keep a few rounded sticks of GA Pecan wood in a trash bin. I make mostly acrylic, Tru-stone, et. al, not many wood pens anymore.
Before I put a new woodchuck insert edge on Tru-stone , sea shells, etc, I cut a couple of the "rock hard" pecan blanks into something. The Chuckie is so sharp that if you don't take VERY light cuts with a new insert, it will expose all of you shortcomings in PR casting.
