Why two drill bits for Jr. Gent fountain pen?
mecompco
Fairfield, Maine
The cap uses a 12.5mm tube, and the body of the pen uses a 10.5mm tube. If you look at the view of the components, you will clearly see that the cap tube is larger than the body tuve. Thus, the need for two different drill bits.
Regards,
Michael
Dan Masshardt
Mechanicsburg, PA
In general, most kits that require a cap will have two different size drill bits.
You are probably aware of this but in case not, the Jr gent rollerball is exactly the same drill bits and bushings as the fountain. And many other 'Jr' kits and others as well.
