I got my first cane looking pretty good, it took some whittling and plenty of glue, I'm not sure it will hold.
Now I'm working on another and there must be a better way. Installing the connectors is what I'm having trouble with. Do I drill and tap both ends of the connectors? I have a tap for the ends that have standard machine threads, but the other ends of the connectors have wood threads, do I need to get a tap for that? Is there a trick (other than carefully eyeballing it) to make sure the tap is cutting perfectly square to the turning?
Also the handle is connected to the top turning with a tube about an inch long that is threaded on the inside, it is course threaded too. Do I need another tap for that.
Finally, when the connectors are screwed into the tapped holes they will need to be glued in won't they? Otherwise it might unscrew from the wood instead of between the connectors as intended.
