leehljp
Member Liaison
I posted the below on cmcfalls" "Drill Press Speed", but feel that this picture deserves its own post. Chigdon's encouraging response made me think about doing this.
Below is a pict of drill speed results done by an on-line engineer friend of mine on another forum. It is clear to see that the overall speed increase makes for smoother cuts. That test was done in soft pine which will exaggerate the problem of roughness. It does not reflect what will happen in most of the woods that are used in pens. It does reflect the what using the wrong speed for a given wood or PR. PLEASE NOTE the chart below the picture as it gives the correct speed for different density woods in relation to the bit size.
The above paragraph was edited for Dario and Redfish who could not understand my Japanese form of English.
The original link is from BT3Central and was posted by LChien; The pict above is posted with permission from him. To see the original link Click here!.
Please don't think that 3000 RPM is the best for all wood and all sizes as there are variances - see this:
Recommended Drill Speed Chart for Different Wood and Bit Size:
http://www.woodmagazine.com/wood/story.jhtml?storyid=/templatedata/wood/story/data/85.xml
(The size above was increased so that no one else would miss it.)
