InvisibleMan
I want to see if my threads are good enough to just dump ink into the barrel and use that way. I think that's called an eyedropper, correct?
Anyway, do I simply put ink in from the section end and put a little silicon grease on the section threads? Seems easy if the threads don't leak.
I've been using 9 x .75 threads for the section. I think that should work. If I like this, would it be better to get an M9 x .5 tap and die for future pens?
I have an idea for a blank I'd like to try for these, so hopefully it'll work out.
Thanks.
Thanks.
