Threads not concentric
Simplex
Mather, Ca
For those of you who cut your threads with a die like I do, I was was wondering if you ever had an issue with your threads not being concentric. I recently finished one of my kitless fountain pens and when I screwed on the cap I found that the cap was shifted off to one side of pen more than the other. From what I can see, my die will not sit in the holder in a way that aligns the center of the die to the center of the die holder.
Does anyone else have this issue?
Dalecamino
Local Chapter Leader
Indianapolis, In.
If there is an adjustment screw in your die, it could be sticking out just enough to prevent the die from seating into the holder. I took a small file and, cut a groove in the holder wall. Just a guess.
soligen
Sterling Heights, Michigan
Try making an "on ramp" where the die engages the blank to cut threads. This on-ramp helps align the die to the blank (assuming your tail stock is not locked down).
See my tutorial on bulb filler that was just posted for an example
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
Which die are you using that is giving you problems? Or is it the same for all dies?
Russianwolf
Martinsburg, WV, USA.
Are the threads consistent around the piece? If it is truly cutting off center you will have threads that are fully cut on one side and on the opposite side the threads will be less than fully cut.
The other possibility is that the cap was drilled off center. So check to see if the sides of the cap have a consistent thickness.
Simplex
Mather, Ca
if the dia is not secured, to prevent it from moving off centre then one thread will start to cut before the others and this will pull the threads off centre
A longer lead and one of these http://littlemachineshop.com/products/product_view.php?ProductID=2314&category=
should fix the problem
I had to laugh when I opened the link; this is exactly what I use right now. I have noticed that the diameter of the die is sufficiently smaller than the diamter of the die holder such that the center of the die does not align with the center of the die holder.
glycerine
Fayetteville, NC
Gary, I noticed the exact same phenomenon with some of my dies in my homemade die holder (which is much like the LMS one). What I did was took an empty soda can and cut a few thin strips as shims and wrapped these part way around my die before inserting it into the holder. (I do this on the opposite side as the set screw, obviously because if the die will be off center, it will be becasue the pressure of the set screw is pushing it off center.) I am able to get the dies centered and haven't noticed any issues so far.
RichF
Mount Laurel, NJ
I used a similar approach as mentioned above. I shimmed my dies with a couple of small strips of aluminum tape so it rests centered in the die holder.
Curly
Saskatoon SK., Canada.
There are two ends to that holder, one for the 1" die diameter and the other for the 13/16" die diameter. By any chance is your die the smaller one and you have it in the bigger end?
Simplex
Mather, Ca
I thought about that, too, but the die does not fit into the small end. Like the others, it looks like i will be shimming the die.
