Jgrden
Where do I look for a quality set for turning fountain pens?? Harbor Freight??
John, I'm not trying to be a smart-ass, but if a person is looking for something of quality, they don't usually look for Harbor Freight to have it. At least, that's what I've been told.
Len
Are you looking to go 'kitless'?
If so HF and most other local stores won't have the sizes you're after. Some may be able to order them, but you'd likely pay a premium.
As noted above some of the IAP vendors carry some of the ones you'll be after. Victor machinery (Victor Machinery - Metalworking tools and supplies) is a good source for the common metric sizes (though the M9x.75 die is out of stock).
If you're looking at kitless you'll want to do a bunch of research and some sketches to figure out which ones you'll need, it's not that many you'll actually need.
AK
We do have a couple of the M9 x .75 sets available this morning. These are the adjustable dies. This is a good size for the body to section connection and it doesn't matter if it is a FP or RB. Other sizes are based on what you are making and where. FPs require specific taps for the feed holder. Cap to body will be based on the size of the pen you are making and if you want single or triple starts. I would say you should look at what you want to make first and then go from there to determine the size of taps and dies that you will need. Unfortunately it is not as simple as buying a set of tap and dies as the sets rarely have a size that you will use.
AK
I've not used standard nor have I done enough with metric to give you an honest opinion.Which do you prefer using MM or Standard? Makes no difference to me, just how kits are calibrated.
I went metric based on my research here, metric also comes in finer thread sizes which is well suited for pens.
AK
