monophoto
I got my start in woodturning making pens, but I've sort of wandered away, and now only occasionally make a pen using a commercial kit.
The lathe I started on had an MT1 spindle. I have since upgraded to a lathe with an MT2. That's significant to the problem I just encountered. Rather than purchasing a new pen mandrel, I opted to purchase a sleeve that allows me to use my MT1 mandrel in an MT2 spindle.
To the best of my recollection, I've made two pens since I upgraded lathes. The first used a typical two-blank 10mm pen while the second was a 7mm stylus that only had one blank.
So this afternoon, I went into the shop to make another pen using that same 10mm kit that I used last year. I got to the point of mounting the blanks on the mandrel, and found that I couldn't extend the rod in my adjustable mandrel far enough to accommodate the blanks and bushings for the 10mm kit. After fussing a bit, I eventually concluded that the end of the rod was mushroomed very slightly - just enough to keep it from sliding into the body of the mandrel. Now I could understand how that could happen if I had been using the mandrel on the MT1 lathe - repeatedly using the knockout bar with the mandrel adjusted so that the rod protruded slightly from the end of the taper could easily cause it to deform. But what I can't understand is why I didn't have this problem when I made that last 10mm pen, and it how it could happen I was using the mandrel with a sleeve - the knockout bar only comes in contact with the sleeve, it never touches the mandrel itself, much less the rod.
The solution was simply - carefully grind the mushroom from the end of the rod.
But how did it happen?
