I'm considering buying the Sherline lathe with Hut's carriage control system.
http://www.hutproducts.com/lathes9.html
I'm curious if anyone uses or has used the carriage control system that they sell with this this lathe.
It seems to me that the lever could give you a lot of leverage that you may not want. A little movement of that handle could transfer a lot of movement on the carriage that might make your final pass a little uneven or rough. I'm sure that could be sanded out with no problem. I'm just worried about how a twitchy hand could possibly cause a blank to blow out on the final pass.
Any experience with this setup?
By the way, I'm also finding the need more and more to do machining. As far as I can tell, tabletop machining is unrivaled by Sherline products...another reason for picking up this lathe.
Thanks,
Brian
Thanks,
Brian
