Resaw blade for a Laguna 14 12
John Eldeen
Sacramento, CA
So as you can imagine from the title I am in the market for a resaw blade for my band saw. It can take a 3/4 inch blade so I am thinking the is the size I will go with. I will be cutting mostly 3 inch and down materials ,mostly hard and figured wood. I currently use a timberwolf 3/8 3as blade for everything. But I have some plans for projects that I will need to cut a bunch of veneer for and the cut with my current blade is just not good enough. This finally leads me to the question that I could use some help with. The tooth count and set. Less teeth like a 2/3 vpc should get the job done but, in my reading more teeth like 14rk will produce a better cut but the feed rate will be slow? Maybe the answer is somewhere in the middle? My only concern is the cut quality. Any advice would be greatly appreciated.
For your saw I would seriously look at the ResawKing blade. It is carbide and it can be resharpened and does cut well. You can get away with less expensive blades but if cutting alot of exotics they will dull faster. The key to a great cut though always starts witha well tuned saw so do not blame the blade if your cuts are not smooth. Disclaimer, this is just my opinion.
John Eldeen
Sacramento, CA
I believe that my saw is setup correctly as I do get a good cut with the current setup. However I would like a better cut than what I can get now. I just don't know that I am ready for the cost investment of the carbide blade at this time. One day I my look back and say I should have done it but today is not that day. Right now I'm really looking for feedback on any experience with different tooth count and tooth style. With that being said thanks for you input and opinion.
bmachin
Owensboro, KY
Here's a quote from one of my earlier posts:
"I generally end up making this same post a couple of times a year whenever bandsaw questions come up. Give Iturra Designs a call at (904) 642-2802 and ask for their catalog. It contains a wealth of information and opinion (some of it quite strong) on saws, blades, and accessories. About the only thing that they don't sell is saws.
They don't have a web presence, so you'll have to call, and I'm pretty sure that they charge for the catalog, but you'll find more technical and practical bandsaw information there than in any other one single place."
I'm have no advice on what you should buy, but I strongly advise you to cough up the 5 bucks (or whatever the current price is) for their catalog--it's a real bandsaw/blade education. They are also quite good with advice over the phone if you tell them what you want to do.
Hope this helps,
Bill
Dieseldoc
Livermore, Ca 94550
Hope this helps,
Bill
Bill:
I called them today and were very helpful and sending catalog out No Charge.Thanks for the lead.
Cheers
Charlie
mmayo
Tehachapi, CA
I own that saw and the 3/4" resaw king. Excellent or better is my evaluation. If is broke tomorrow I would order a new one instantly. It is a wonderful combination.
John Eldeen
Sacramento, CA
Bill:
Cheers
Charlie
After you get a good look through at it let me know what you think I may have to order one myself you just can't have to much good reference material.
mmayo
Tehachapi, CA
Mark:
How offen do you need to have resaw king sharpen?
Good question, but no answer so far. My only source of quality sharpening is Daily Saw in South Gate, the occupy a city block and are very busy with meat cutters like Farmer John etc. I may buy a second one and alternate them.
penicillin
Iturra Designs:
This is just another "cheer" for Iturra Designs and their truly deep knowledge of bandsaws. As Bill (@bmachin) states, they have no internet presence at all. They take phone and mail orders only. I buy nearly all my bandsaw accessories from them. They are simply ... the best bandsaw resource ever.
(904) 642-2802
Industrial Blade:
The one exception is that I buy bandsaw blades from Industrial Blade. They service the entire country, but they are local to me. I go to their shop and they make the blade(s) while I wait. They carry the name brands that have been mentioned above. They have a toll-free number and take phone orders from all over the country. Highly recommended:
1-800-SAW-BLADE (1-800-729-2523)
http://www.industrialblade.net
