LandfillLumber
Okay I'm back to thinking its the transmission(see first two post about truck below),I had a tranny guy tell my father that it was a piece of plastic that keep the shifter in the right spot that is worn down and causing the tranny not to go into first gear.I have a ton of slop in my shifter when it is in gear,he claimed he was almost positive that is what it was(he owns a tranny shop).I didn't talk to him so heard the info. second hand I got no name to the part so I need help.I also read online about a guy with the same problem and he said someone told him it was an aluminum plate that has worn out not holding it in gear.I have looked for over an hour on the internet with no results,I need to know what this part is.I would love to see a schematic of it if possible,but my library didn't have my trucks manual.HELP PLEASE between my knee and truck my pocket book is empty,but I always have lots of wood,LOL.Thank you,Victor
Second post on the truck
Hello, so I'm a little stupid about autos and thought that my truck was not going into first gear as it was acting like i was trying to take off in third.I was wrong its going into first but it will not take off normal,it jerks and acts like it doesn't want to burn the fuel.My uncle said that he thought it was a air line that goes from the air filter to the top of the engine.Is this the lines coming from the manifold?I have one that goes from one manifold to under the carb,then one that was not attached to anything coming from the other manifold.The air filter has a port for a line but it is larger then the hose coming from the manifold?I'm sure I'm just confusing people as I'm very confused myself.Any help would be great,Victor
My first post on the truck
Hello, my 88 chevy pick up manual transmission will not shift into first gear,but all other gears just fine.I had to take off in second to get home this afternoon??I searched the internet and found someone with the same thing happening,Someone replied that it was a synchro?I see Synchro rings kits that are not that expensive,my question is this has anyone changed these or had it done.I wonder how hard it is or how much it would cost to have it done.Maybe someone else has another idea what is causing this to happen.Any information would be great thanks for the help in advance,Victor
