KBs Pensnmore
Anyone had a problem with the toothed drive pulley on the motor on a 7X12 lathe? Mine has come adrift causing the pulley keyway to be ruined and also the slot in the motor shaft to be shaped into a V.
Should it be a press fit, as there doesn't appear to be a slot for a circlip or threaded for a bolt?
Is there an easy fix or am I looking at a new motor as well as a new pulley and belt?
Regards
Kryn
Regards
Kryn
