Problems with Cigar pen
pen-turners
Honolulu, HI, USA.
I've turned about 100 of these and never had a problem but tonight when I was assembling my cigar pens I made the tip of the rollerball insert won't fit through the tip of the pen. It is physically too big and does not fit. I pulled out a couple of other kits and they are hit and miss. I thought maybe the spring was binding so I took it off and had the same results. Anyone else had this happen???? Do you think I will mess up the finish if I bore the tip out slightly????
Let me know,
Chris
KKingery
De Pere, Wisconsin, USA.
I've had that problem when switching to a gel refill, but not with the rollerballs. My personal opinion, is that the problem is not with the refill - I think it's with the pen tips. If you have a good scratch awl, you can slightly enlarge the tip hole, and it should be ok.
dougle40
Essex, Ontario, Canada.
Another thing that could be wrong with the tip is that there could be a slight burr inside the nib hole which could easily happen with parts that are mass produced . Inserting a small drill (the size that the hole should be) and turning it by hand , from the inside , will remove a burr.
pen-turners
Honolulu, HI, USA.
Will try to file them. I have a set of small round diamond files and will try to loosen it up a bit. Another problem I had on these kits is you can take off NONE OF THE TUBE while squaring. If you even shave off a MM it will cause the tip of the pen to stick out and not work correctly. I verified this by assembling one of the kits with just the tubes and it was still close. Guess the tubes are a little short that were supplied with the kits.
Tom McMillan
Washougal, WA, USA.
Yes, Chris---I had the same problem with the cigar pens---coming with tubes a little too short---I solved that by buying the long tubes from PSI and cutting my own to length.
