inemoy
Looking to purchase 11.5 mm brad point drill bit can't find it
Thank you
Thank you
Thank you for quick response but it's not a brand point but thank you if I will not find it will definitely get this one
Thank youFisch makes a set and I don't know if they sell individual bits or not. Here is their web site: https://www.fisch-tools.com/en/
Here is a set for Fisch on Amazon that INCLUDES an 11.5. You have to look down the page to find that the set offers metric in full and .5 sizes up to 13.
that is a high price just to get one. If you check with the company, someone might be able to help you with the 11.5 only.
One other item is - while they are listed as brad points, they do have a center point but the edges do not have protruding edge points as most people call brad points.
Here is another set at half the price of the Fisch but I don't know the quality
Thanks for this, Dave.I am not trying to open a can of worms here. Although there are those that swear by brad-point drills, I have put nearly all of mine away and almost exclusively use standard twist drills. Although the brad-points make a clean entry hole they can be prone to cause more tear out on the exit side because the last few wood fibers are unsupported so pressure makes them bend and tear. They are also difficult, if not impossible, to sharpen and are generally more expensive to manufacture than standard twist drills of a comparable quality.
That being said, many of us are successful with standard twist drills as much as many are successful with brad-points, so don't put too much emphasis on the style of bit you use.
Dave
the drill doctor will sharpen a brad point of you take it to a grinder first and change the grind on it . I've done this to a few brad points that have given me fits.Thanks for this, Dave.
I was wondering what the thoughts were here about brad point bits. I've got a collection of both. I know the Drill Bit Doctor doesn't sharpen brad points, so that makes them rather disposable.
Thanks for this.the drill doctor will sharpen a brad point of you take it to a grinder first and change the grind on it . I've done this to a few brad points that have given me fits.
