NEJE 1500 HELP
jcm71
Chattanooga, TN
My recently ordered NEJE 1500 arrived today, and I have to admit I am completely stumped on how to get it to work. I have a Mac, Ipad and iPhone and none of them recognize the NEJE on bluetooth. I am not even sure that what I ordered is a 1500 as there are no markings on the thing identifying it as such. I'm also not sure if the thing in front of me is bluetooth capable, since not of my devices recognizes it. I currently have it plugged into a known good USB port on my Mac, and the Mac doesn't know it's there. I swapped out cords. Same result. Any suggestions and help greatly appreciated. Thx.
John
Terredax
Banned
I know nothing about the NEJE, and it may be a stupid question, but is it MAC compatible?
Terredax
Banned
If it's Ipad and Iphone compatible, wouldn't it be Mac compatible? They are all Apple products and they link to each other.
Just thought I would ask, since sometimes it's the obvious.
jcm71
Chattanooga, TN
Seems logical to me, but then again I am no where near being computer literate.
Magicbob
Akron, OH
I have the 1500BT
Mine is hooked to a PC most of the time, but I have sent a print from my iphone
leehljp
Member Liaison
Tunica, Mississippi,
No. The Mac OS and iPad & iPhone OS are different. Because they are from the same company, many of the different apps' files are written to work with apps on either OS. Similar to Word or Excel files working cross platform on Windows or Mac Apps.
I got my NEJE last week end but have not had time to hook it up. My shop is still in transition and I don't want to break the NEJE until I get my table/bench in the right place. That said, I have Parallels Desktop 12 and Windows 7 which I have not had problems running any Windows apps thrown at it. I have been very surprised at how well the Macs USB ports work in Windows and how all of the different brands of networked printers work on the Mac OS side and on the Windows side, and wirelessly. The Mac should work through Parallels and Windows if they are installed.
I will be watching this thread for when I set mine up.
larryc
Mableton, GA (Near Atlanta)
If it was not advertised as a Bluetooth, it probably isn't. I bought one of the Bluetooth units and couldn't get it to work on my Mac. I sent it back and got a non-Bluetooth model and downloaded the Mac software available on the internet. Ignore the warnings about viruses.
jcm71
Chattanooga, TN
I think I figured out the problem. It says you have to have Bluetooth version 4.0. As I have an iphone 3G (I think) I probably have an earlier version of Bluetooth installed that is not compatible with the NEJE 1500. If that's the case, now I get to go buy a $700 phone to get my $100 engraver to work. Go figure. The NEJE is coming with me when I go to the Verizon store.
jcm71
Chattanooga, TN
Scratch my previous post. Finally got it to come on by downloading the NEJE printer app to both iphone and ipad. The problem is that the Apple app is different from the Windows program. From what I can see there is no way to import text to engrave it. The ipad app only allows you to import pictures from your photo library. If you hit the controller button, the device controller screen comes up, with what appears to be a text box in it. If you tap it to type text, a keyboard comes up, however, it partially blocks the controller's control buttons, and there is no apparent way to make the keyboard disappear so that you can see what you have typed and have full access to all the controller's functions. If you do import a photo from your library, after importing you have to hit the "Effect" button, which gives you a black and white negative of your picture. It takes forever to send that negative to the engraver. I'll keep playing with this, but so far, as far as I'm concerned, it is a bust for Apple users.
leehljp
Member Liaison
Scratch my previous post. Finally got it to come on by downloading the NEJE printer app to both iphone and ipad. The problem is that the Apple app is different from the Windows program. From what I can see there is no way to import text to engrave it. The ipad app only allows you to import pictures from your photo library. . . .
. . . If you do import a photo from your library, after importing you have to hit the "Effect" button, which gives you a black and white negative of your picture. It takes forever to send that negative to the engraver. I'll keep playing with this, but so far, as far as I'm concerned, it is a bust for Apple users.
If I am understanding this correctly, It will import a "picture". If this is true, then there is a way around this. I often type text into picts/photoshop graphics and save the whole thing as . I do this with Text on a white background and save it as a ".pict" or ".jpg" in the equivalent of 300 dpi (or other) etc. At this point the text IS a graphic/picture and not text.
The problem will be the amount of playing to get the right size text into graphic to print/burn onto the pen.
Your post here had been extremely helpful! Thank you very much for posting this question and information!
jcm71
Chattanooga, TN
OK, finally figured out how to engrave text on the NEJE using an ipad. If you have Pages (rudimentary word processor for ipad), download it. Open up Pages and select "Blank Landscape." When you go to type in text, the keyboard will come up. In the upper right corner select center justify and your font size. Without a rotary jig, 96 is probably the highest you can go for a single line. In the upper left corner select your font. Not too many fonts available. Use your return key as necessary to position the cursor as close to the center of the page as you can, and type your text. In the lower right corner press the keyboard button to make the keyboard disappear. Now take a screen shot by holding the power key and then pressing and releasing the home key. Your screen shot is now in your photo library on your ipad.
Close Pages and open the NEJE app. Press the Search button to connect your Ipad to the NEJE. Now press the Photo button, then Album, and then select the text you just saved. Now hit the Effect button and then the Send button to send the picture to the NEJE. Unfortunately with an Ipad this takes about two minutes or more. Position your blank left to right on the table, so that the center of the blank is under the laser beam. Use an appropriate sized transfer punch in your blank and secure each end of the punch under the rubber bands. Press the Controller button on the App. I adjusted my burn time to 90 for a blank with a CA finish with good results. Play, experiment, and have fun. Hope this helps someone.
Now that I have this figured out I guess a rotary jig is in my future.
PMBROTH.NY
New York
I use both windows and OS X and iPad and android. The app specifically for each platform works. Trustfer.com. Get the latest version, they just released a new version a few weeks ago for mac and a new version for pc.
Makereality
Lakenheath UK
I wasn't able to find/ run the Mac software, it is or at least 2 months ago was in beta. I run parallels with windows 7 and the only problem I have found is that it wants to draw fonts from microsoft, but I didn't
install word on the parallels version of windows, as I have word for mac. So some fonts if selected will come up error about not being a "true font".
With respect to what strength laser you bought, loosen the two Allen wrench nuts off the laser head support and pull it out- it may have handwritten in black ink a European style 1 which looks like a musical rest or fancy 7 to American eyes. It would say 1.5 if it is the 1500 mw.
By the way, you can buy the 1.5 and swap it out into your 1 w motherboard and it should work.
Also, as far as images or even wording, you can hit the redo button and it will make it very crisp, my last pen handle I burnt 3 times the name and I was very pleased. Hope this helps.
jcm71
Chattanooga, TN
Ok, I have to amend my last post on getting a NEJE 1500 to work with an iPad or iPhone. The NEJE app for these two items is way to limited and flawed to get a professional result. First, when taking a screenshot, as I described in my earlier post, the info bar icons at the top of the page are included in the screenshot. These could possibly by edited out by a rudimentary drawing app like Atom Draw, but it is way too time consuming. Off course if you don't edit it out all that crap at the top of your picture, it will get engraved. I'm sure there is an easy and efficient way around this, but I'm not computer savvy enough to figure it out. Another major flaw (fatal flaw) with the NEJE App for Ipad is that after you hit the Effect button in the App, a vertical line appears to the right of the image. There is no way edit this line out before sending the image to the laser (which takes forever), and it is of course also engraved with your picture. This one flaw needs to be fixed before the NEJE 1500 can be used with an iPad or iPhone.
I'm curious if Android users have similar issues.
Yablonsky
Aliso Viejo, CA
I've got a MAC and have, I think, parallels installed with Windows installed. Plugged the NEJE printer up and it prompts me if I want to recognize in the mac of parallels....selected the later and then launched the supplied burning app and it works like a charm. You are limited in fonts to what is installed in the OS...but I have Corel Draw with tons of fonts and they are all available.
Good Luck with getting it working.
Ken
Dale Allen
Massillon, OH
I purchased the Meterk DK-BL 1500mW today. Did not order an extra laser unit as I want to see how it works first.:)
Can anyone tell me what this means? It is in the description for the laser on Amazon:
"* When connected to a computer,there will be a flashing breathing light to tell you that it is put in and put out":cool:
jcm71
Chattanooga, TN
My guess is "When connected to a computer, there will be a flashing, blinking light indicating the computer and laser are communicating."
Claremont NH
I purchased the exact same unit Dale.
NLAlston
Amherst, NY
I got mine through amazon. I was told i would have a better chance of getting it replaced if it is DOA and that Gearbest does not guarantee much.
Dale has it absolutely right.
A few months ago, I had bought from GearBest - and all I can say is that it is best NOT to do business with GearBest. I submitted a posting, a bit more recent than that, regarding a very unsatisfactory handling of a defective NEJE unit - after (mind you) just ONE somewhat successful engraving with it. I wound up with them NOT honoring their warranty, and a $15 refund returned to my credit card. Had I not have bought another unit from them, before that, it wouldn't be here, in my possession, now.
Some folk are experiencing great relationships with these little, inexpensive laser engravers, and I wish that I had been one of them. I WILL invest in another one, but it will be the 1500Mw burner - AND, it WILL be through Amazon.
GearBest? Never, EVER again.
Dale Allen
Massillon, OH
Thanks Nathan, but credit goes to Magic Bob here.
He gave an extraordinary demo of the laser and rotary attachment at last weekend's meeting in Hartville. His recommendations of where and how to buy one was noted. Thanks Bob, you are a good salesman!:)
Dale Allen
Massillon, OH
I guess the phrase 'lost something in the translation' applies here.:rolleyes:
Claremont NH
After I found the on/off button I am up and running. I have done 3 or 4 small prints. Will put a pen to it tomorrow and see how it does. How much power are you guys putting to it for a pen?
Claremont NH
OK so this thing works great for pen engraving. It has plenty of power it is very adjustable and easily adjustable. I was able to put my font into windows and life is really good on it. This does a nice enough job for pen engraving. Yes there are betters ones but this one works great! Very happy.
DJBPenmaker
Cheshire, UK
No issues with Android or Windows. When I can only use the android app and Bluetooth for images I take the photo, convert it to a sketch using the photo editor app, then import it to the laser app. Get very good results. Can't figure out how to get different fonts when having to use the android app for writing though.
Sent from my Nexus 6P using Tapatalk
Magicbob
Akron, OH
Dale, when you are ready for a jig call me, we can meet up and save you the shipping.
DJBPenmaker
Cheshire, UK
I purchased the Meterk DK-BL 1500mW today. Did not order an extra laser unit as I want to see how it works first.[emoji2]
Yes, when it is connected and in idle mode the laser pulsates in low power.
Dale Allen
Massillon, OH
Well, it works fine. Now for the learning and experimenting.
Thanks all for the information.
Bob, not yet. There is much work to do on flat stuff before I get to rotary.
And, I make a lot of fixtures and jigs for work and making a rotary jig for this seems like my kind of challenge!
