so i tried the silicone caulk mould. after letting it set nearly a week i tried to take it out of the mould and the caulk was still not dry. any tips on making these thing?
thanks
If you are using the silicon that smells like vinegar, you may add a bit of corn starch to the mix and it will set up faster. A mix of 1 starch to 4 or 5 silicon works pretty quick. Much more than that and it does not want to mold around your positive. DAMHIKT
Charles
What you need is "acid cure" or "acidic cure" silicone. If you use the right stuff it will take 1 - 3 days to fully cure depending upon the thickness of the mold.
