Long Click TBC bushings
longbeard
West Virginia
I don't have an extra set but, i THINK (not sure) the bolt action TBC bushings are the same,( as far as fitting the tube ) you would just have to get close to size then mic to final demension. I have done this when needed.
Harry
ChrisN
Denver, PA
Harry
I do have a set of bushings that (I'm fairly sure) fit the LC tubes, but the kit they are for is ~.02" smaller. I could probably make them work - I just use the bushings as a guide for shaping and do the final sizing directly between centers - but I would really like bushings that are made for LC pens so there won't be as much caliper work.
Charlie_W
Sterling, VA USA
Check with Classic Nib. Roy is carrying between centers bushings now. As of MAPG, he had bushings for some kits but not all. He was expecting more shipments which would have other sizes.
Laser Linez is making these and had a few on their site as well.
ChrisN
Denver, PA
Last time I checked (which was last night, BTW), none of the 3 suppliers I know of had them.
Charlie_W
Sterling, VA USA
You could make a set from Corian or even a hardwood. I have a few from Corian and some from ebony. They are not perfect but they are closer than the stock bushings.
If you have a friend with a metal lathe, you may be in business.
ChrisN
Denver, PA
I know I could make my own, but I like the tight tolerances of the steel bushings.
