Lathe speed for plastic blanks
CabinetMaker
Arvada, CO
What lathe speed is best for turning plastics? I know that there are several different types of plastic blanks that vary in hardness. Some are very hard and brittle and pit very easily when turning. Others are a bit softer and turn much more cleanly.
So what lathe speed do you find works best for different types of plastic blanks? Thanks!
MikeG
Fort Wayne, Indiana, USA
I just finished my first 25 Corian pens and this is what worked for me:
700 RPM to take the round over the edges.
1200 RPM to full round.
2400 RPM finish shape
700 RPM sanding / micro-mesh
2400 RPM polish
These were my first Corian pens, but I am happy with the way they came out. There was no chipping or blank breakage, but these speeds may be slower then others run, as I do these for fun and not for profit.
I know "no picture - it didn't happen"
HSTurning
New Hampshire
My jet mini makes some odd noises at top speed so I turn everything at 1 from the top so that 3200-3400. I sand, I finish (CA) and wet sand the finish at the same speed.
ToddMR
Columbus, OH
I turn at full speed on most everything. I find catches are not as bad as it tends to skip over it. At least that's how it appears to me. I only slow down to do CA finishes as not to sling CA. Someone suggested to run full speed to me last year and since I have, I have not looked back. :)
CabinetMaker
Arvada, CO
I'm glad I asked. Since I drilled 'em slow I was going to turn them slow. It makes sense to turn 'em fast so that my cut rate goes up. It also seems that a face shield over safety glasses is a good idea.
GoodTurns
Bowie, MD, USA.
JimB
West Henrietta, NY, USA.
A face shield is always a good idea not matter what you are doing or what material you are doing it with.
