K40 40 watt Laser Questions
keithbyrd
Mount Wolf, PA
I know lot of people have the NEJE lasers and a few years ago several had the Chinese K40. I have a K40 Laser about 7 years old - it has been good and I have done nothing to it. Which mean it needs some help! Power has gone way down and way out of alignment. I decided to correct my ways and get a new tube and align the mirrors. So Mirror 1 (out of the tube ) and mirror 2 have bad spots that can't be cleaned off - looks like a burn spot on mirror 2.
Does anyone know a good source for these mirrors? and the 40w tube?
Thanks in advance for your help!
Fuzzy63
Montpelier, Indiana
Hello Keith, I also have a K40 laser. You can get a new tube off E-Bay for around $100.00 and the lens around $36.00. Just do a search for each one of your items and you will find them. I done this search just a few ago and came up with these items. Hope this helps you. You can also order the little nylon rollers on the slide if yours are worn also.
Gary
444
Darlington, SC
If I were going to replace my original 40 watt laser tube I would go for an upgrade. A 50 watt tube is 97.00 and a 50 watt power supply is 50, you are going to have to cut a hole for the longer tube and they even have a plastic cover for that. The only real difference is a new power supply and cutting the hole for it and you get 25% more power.
keithbyrd
Mount Wolf, PA
thanks for the responses - have ordered the parts - I decided to stick with the 40w tube - I'm not big into modifying working things - I guess I'm a little timid about screwing something up!
