I put together my new bandsaw and here are my observations:
Amazon – Amazon was easy to work with as always. Click on the product, pay, shipped. No issues
Packaging – The packaging was very good. Everything was packaged in a nice sturdy box with plenty of form fit Styrofoam around all of the handles and the body. No issues
Assembly – The instructions that came with the unit are good. I had no issues putting the unit together on my own. The saw is not that heavy and I was able to easily lift it myself fully assembled. No issues
Adjustments – Here is where I started running into some issues. I went to level the table and tightened the tilt control. With the unit as tight as I could make it I could still easily tilt the table. I tried to adjust the tension with the small plastic screw on the bottom and it does nothing to control the tension. I disassembled the table and removed the tilt unit to see what was going on. Everything looks like it is sealed so I cannot make any adjustments. I called today to see what might be going on and they advised me to take it apart again and see if I am missing any pieces. More to come.
Quality – the unit is all aluminum with a nice heavy cutting table. The extension is convenient, but I don't think I will need it. However, the upper door hinge welds popped so I am going to need a replacement.
Power – Not there… I was cutting a piece of pine 2x4 to see how well it cut. It was fine as long as I did not push too hard, it did stop when I did. But if I went slow and steady it cut fine. I intend on using it mostly for pen blanks and small projects anyway.
