RobW
I just bought my 3rd pen mandrel (first was the el-cheapo from Woodcraft, then the adjustable length Penn State, now just a new shaft for the adjustable). Using it on a little Wilton mini-lathe. The first 2 I think I bent out of shape by cranking on the tail stock too tight. This new mandrel, I just twist the live center into the mandrel until it just barely snugs up. Only turned about 10 pens on this new one, and already it looks out of whack. I can feel that the bushings by the headstock, when running are very smooth, the ones by the tailstock seem like they almost wobble when the lathe is running. Maybe that's not a good way to explain it, but it just feels like the mandrel is not perfectly straight.
My live center is that low-end one from Woodcraft with 2 interchangable tips, and the pointy tip is kid of chewed up from tightening too much with the other mandrels. When I bring the tail stock up to the head stock, the points seem perfectly in line, so what would make the tail-end of the mandrel seem to have run-out? Do I need a better 60 degree live-center? I need to make about 35 pens in the next 12 days, so I don't have time to mess with this.
Help....
Rob
Help....
Rob
