chris99210
I had a return of a PSI stylus as the rubber tip split and came apart. This is the older stylus where the tip is press-fit, not threaded. The clip end is also press fit. I just want to replace the tip but am struggling with how to remove the pressed-on tip ring without damaging other parts (I don't care about the ring and tip, I'll just press on a replacement). I may have to grasp the ring with needle nose pliers and just pull, but before I do that I thought I'd see if anyone else has had to do the same fix.
Thanks,
Chris
Thanks,
Chris
