Help!!
RDH79
Rimersburg, Pa, USA.
I glued up a couple red crush acrylic and I didnt paint the tubes dark enough to get the color I needed. And they are already turned to size. Any ideas how to unglue the tubes. I used 5 min epoxy. Manybe I should just start again.
RDH79
Yea I just called and ordered more or the red blanks and tubes. I should have went back to bed this morning. I know it was going to be bad after going to my mothers and tried to fix a water leak. Ended up calling the water company and a plumber. Please dont ask for details. Its been a bad day.
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
Can you run the drill bit back though the blanks and drill the tubes out? Or is the shape of the blank going to prohibit you from doing that?
RDH79
If I wouldnt have already turned them I would try it. But there turned to size and the acrylic is thin at the ends. It would probably ( my luck ) crack the blank. I can use them but not for this order.
