Califo
I have a rookie question, I know you may have an answer. I find that when I turn slimlines, the blanks are usually tight slipping onto the mandrel. Do you normally do anything to avoid this? Today I was working on slimline that turned out better than I expected and when I tried to take it out of the mandrel, it was stuck to it. I had to ruin the pen in order to take it out. Could it be glue/epoxy, dust, the tube diameter narrower than the mandrel? Either way, how do you avoid this? This is the second time this has happened and othertimes I am able go get the finished blank out but it is tight.
Any help is appreciated.
