Help! Which tube????
RonSchmitt
Milwaukee, Wi, USA.
Have to make a cigar pen/pencil/letter opener set for a customer, snuck out of a meeting early, made it to Woodcraft with 15 minutes til closing.
Got the pencil and a bunch of other stuff that was not on the list, and having a senior moment, forgot the letter opener kit.:eek::eek::eek:
Since the opener has to be sent to Ken for engraving, I have time to go back and get the kit before assembly, but does the opener use a standard cigar tube? If so, which one the long lower or the short upper?
Thanks,
Ron
randyrls
Harrisburg, PA 17112
Ron; The short answer is that there isn't anything running the length of the tube so you can make the length whatever you like. I often make the tube longer than a stock tube so you can grip the opener better and firmer.
avbill
San Bruno, CA, USA.
The tube is the same dia as the cigar pen. 10mm. Yet the length is longer than either the tubes of the cigar pen. 77mm or just under 3" I just finished a kit and the length was 77mm.
ed4copies
Local Chapter Manager
Racine, WI, USA.
I concur
Exactly correct!
