opfoto
As some may remember, a while ago there was a discussion about the need for bowl gouges.
I purchased a couple from Doug Thomson after reading a very helpful review in one of the mags and a couple of users here suggested him as well.
I am finally getting round to turning 2 handles from Walnut. I am using the copper pipe couplers from the BORG near me. I decided to do everything on the lathe. I drilled a hole the diam (1/2 and 3/8) and length of the tang (2in) with paddle bits.
The 1st one I drilled while the blank was still square. I noticed a wobble at the tail stock end as I was turning the blank down to form the tenon. I was using my 60degree live center in the tail stock. The wobble continued thru the finishing. The handle looks great. There was no wobble at the headstock...
I know I locked down the tailstock, I tightend the part that is adjustable within the tailstock. The tailstock did not seem to creep at all.
For the second handle I decided to round the blank 1st then drill for the tang. Smaller chisel, smaller bit. Still the same wobble.
BTW, The handles are 15-16 inches long. I have never turned anything quite this long and these are handles for my 1st set of bowl gouges, but I was hoping that this would give me some experience to try peppermills down the road.
My chisel bounced up and down on both handles when tested for round at the tail stock end and lays smooth on the headstock end.
Does anyone know what I can do to remove the wobble?
Sorry for the long post.
