Monty
Group Buy Coordinator
This will make you check that your saw blade is firmly tightened.
I had seen that the other day. I've never worked with a concrete saw so I am curious how that blade fits on the tool.This will make you check that your saw blade is firmly tightened.
Or buy a lottery ticket.The guy who walked in that store just a couple seconds before it hit that wall needs to go to church as his next act. He had an angel watching out for him.
I believe that a worker forgot to check the tool before using it & the blade came off due to a loose nut.Did the blade come off the shaft (lose the Jesus nut) or did the shaft break? Can't see through the hole.
IIRC it said it was partially due to operator error.I believe that a worker forgot to check the tool before using it & the blade came off due to a loose nut.
